Old 11-25-2017, 12:27 PM   #1
Water pressure
I am hooked up to my home’s water. No pressure. I have verified existing pressure and correct connection to my DS25. Earlier I was getting a dribble from the bathroom sink and heard a thunk sound and no more water. In-line fuse and breaker are ok. Suggestions?
wpeterson4 is offline   Reply With Quote
Old 11-25-2017, 01:26 PM   #2
Fauset screens clogged up? I’d check there first
Rdeejr is offline   Reply With Quote
Old 11-25-2017, 01:26 PM   #3
Post
What is the full configuration of your "DS25"?
Year, Make and full Model #
Is there a pressure regulator in your incoming water system?
Cuban Crisis Vet
2017 Forest River SunSeeker 3050S
Ford 450 Super Duty
Just me and the Wife
emeth is offline   Reply With Quote
Old 11-25-2017, 01:33 PM   #4
D W
D W's Avatar
Check for an obstruction/blockage at your CW inlet screen & check valve.
2016 Salem 27RKSS
D W is online now   Reply With Quote
Old 11-25-2017, 01:45 PM   #5
BooBoo23's Avatar
If you have water in your fresh water tank turn on the water pump and see if you get any flow from it, that will help determine where the problem is.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
KT4W
BooBoo23 is offline   Reply With Quote
Old 11-25-2017, 01:47 PM   #6
2017 FR3 DS25. I get dribble from all of the taps. Screen filter in water pump as well in intake are clean. The water pump won't run so there's no pressure from the tank when off city water. Seems like multiple gremlins.
Old 11-25-2017, 01:48 PM   #7
Fuse and breaker have nothing to do with city water. Only for onboard fresh water using the water pump.
2011 Traverse LT, 3.6L, FWD
Old 11-25-2017, 02:04 PM   #8
D W
D W's Avatar
Just a thought, you might have an air lock in the CW inlet line. Remove the screen, stand off to the side and reach your finger into the inlet an try pushing the check valve button. If you have an air lock it will shoot a steam out. An air lock will also force your pump into by-pass mode and it will not pump as it can't overcome the air lock pressure.
Try it and let us know how you make out.
2016 Salem 27RKSS
Old 11-25-2017, 02:37 PM   #9
DW, that resolved the pump not running. Still no significant water flow from any tap. What/where is the common point for both sources? None of the valves have been changed.
Old 11-25-2017, 03:39 PM   #10
Remove and clean the aerators on your faucets.
Old 11-25-2017, 04:09 PM   #11
D W
D W's Avatar
OK, bear with me here, I'm trying to rule out possible problems. With your CW hose disconnected, and left uncapped, if you run the pump, does any water come out of the CW inlet? If this is the case, the check valve inside the CW connection has failed and just possibly sealed off the CW flow inside, but allows pressurized water to flow towards the pump an then into the FW tank. That "clunk" that you originally heard could very well be the FW tank being pressurized by the water from the CW hose and the air has no where to go. Also, some RV's have a check valve inside, normally under the bathroom sink that seals off the FW system when CW pressure is applied.
2016 Salem 27RKSS
Old 11-25-2017, 05:19 PM   #12
It seems the air lock was affecting everything. I now have water with the exception of the bath sink. I'll continue this avenue. I'll also clean out my aerators. Thank y'all for all your assistance.
Old 12-02-2017, 06:22 PM   #13
John Dorsey's Avatar
If the bath sink has check valves hook a shop vac to the faucet. It should open the check valve. I did mine with the faucet on no effect but with the faucet off it fixed it.
2016 Brookstone 395RL
2013 Ram 3500 DRW
2001 Winnebago Brave
1998 Rockwood popup
John Dorsey is offline   Reply With Quote
pressure, water
