As mentioned, don't cap that elbow. That's your vent/overflow. Not sure what the other white tube would be for, but since you have an exposed tank it wouldn't be the overflow/vent for that since it's coming through the floor, higher than the tank. What is inside the trailer above where that white hose is coming through? That may help us figure out what it could be for.
As for your water pump running all the time and poor water pressure, that would be due to a low fresh water tank level. Even though there's still water in the tank, the pick-up for the water pump isn't right on the bottom of the tank and the tank level gauge could even indicate you still have a lot of water but you're still sucking air. If you fill the tank and the pump and water pressure go back to normal then that will confirm the cause. If you fill the tank and still have a problem then that means you either have a problem with the supply line to the pump or you have a leak somewhere after the pump (which should be obvious by water showing up where it doesn't belong).
2017 GMC Canyon - CCLB, 4x4, 2.8L Duramax, ARE Z-series shell
2013 Shamrock 21SS
