Old 01-20-2012, 07:16 AM   #1
preacherpaul
Water pressure
We have a 2011 Silverback 29re and we're having a problem with water pressure. If we remove the filter pressure increases. Anyone else having this problem with a Silverback?
preacherpaul is offline   Reply With Quote
Old 01-20-2012, 07:51 AM   #2
Have you replaced the filter with a new filter? A clogged filter will certainly reduce water flow.
2012 Rockwood 8314BSS
2011 Chevy
Camping, Dutch Oven Cooking, and Homebrewing
campdohbrew is offline   Reply With Quote
Old 01-20-2012, 08:09 AM   #3
P. S.
I had this happen years ago with my first travel trailer - changed the filter and was good to go. Since then, I change the filter every season.
Did you disconnect the trailer and check the water flow for norml operation. In some places the water company will check for the asking.
2011 Chevy
Old 01-20-2012, 08:35 AM   #4
Mountainmanbob's Avatar
most say that this is when the filter is working it's best
a filter is always going to slow down flow
at least a little
as a filter get's used more
flow decreases due to build up
I use them as long as I can
you may wish to start
with a new filter
then if you are still having PSI problems
try bringing the pressure up
at your curbside hookup
MM
Mountainmanbob is offline   Reply With Quote
