Old 08-03-2015, 12:21 PM   #1
Lightbulb Water Pressure
I'm pretty sure someone out there is going thru this...I got a 2015 Heritage Glen 272RLIS, it pulls great and it's very comfortable, one of my issues is water pressure, I've tried in different campgrounds thinking that it was location pressure, but its the same at all locations, including the house. Pressure is low, not only in the shower, but through the whole unit. I just took it back to the dealer for a check up, but want to post it here before I move on to replace shower heads and faucets......Any ideas would be great.
FreddyCamper is offline   Reply With Quote
Old 08-03-2015, 12:29 PM   #2
Georgia Rally Coordinator
aceinspp's Avatar
I think I would have checked and cleaned all faucets as may have trash in the lines. Also filer lines. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped 2017 62
Days camped 2018 67
Days camped 2019 62
Old 08-03-2015, 12:38 PM   #3
Even a new Unit? Just got it 3 months ago..used it only 5 times.
Old 08-03-2015, 02:17 PM   #4
bikendan's Avatar
Especially on a new unit.
Debris from construction is the #1 cause of your issue.
Equalizer WDH
Old 08-03-2015, 03:12 PM   #5
Are you using a water pressure regulator?? If you are, try it without the pressure regulator.
bruceatlam is offline   Reply With Quote
Old 08-04-2015, 10:39 AM   #6
I would try the screens in faucets and if you have a water filter, I would check that also. If you use a pressure regulator please check that. Are you using city water or your water pump? Good Luck
whj77372 is offline   Reply With Quote
pressure, water
