Old 03-28-2015, 02:31 PM   #11
Where to find toilet valve
Can you tell us where the toilet valve is?
wildflower is offline   Reply With Quote
Old 03-28-2015, 02:35 PM   #12
On mine it is at the top rear of the bowl. Easiest is to just remove the commode, cover the hole with something that is disposable to prevent dropping anything in it and blocking odor. Suggest you get some Danco silicone grease (Lowes) and lube everything including the sponge gasket in the floor when you put the commode back.
Old 03-28-2015, 02:39 PM   #13
Are you aware of a separate fuse or does this come off the fuse panel...it seems electrical. We have blown out the lines
Old 03-28-2015, 02:44 PM   #14
Never heard of any electrical connections on a commode. Every faucet and the commode have places that can and do get plugged with anode debris, construction debris, etc and it even happens to campers years old. It is just something inherit to camping.
Old 03-28-2015, 02:48 PM   #15
Thank you...we will keep fiddling with it!
Old 03-28-2015, 02:53 PM   #16
TURBS's Avatar
Has anyone mentioned the little screen mounted by the water pump?
If it has one of course.
Turbs
Old 03-28-2015, 03:19 PM   #17
Yes we have checked
That. We found a automotive flasher in the toilet compartment....? Seems like it is connected to the switch. It isn't a blockage because water will come out when air is blown through.
Old 03-28-2015, 03:37 PM   #18
Yes we have checked
How about a picture? We're all shooting in the dark, don't know the type, make or model of your toilet or set up.
Old 03-28-2015, 03:55 PM   #19
Witch Doctor's Avatar
Will do........I am wondering if maybe that same clog is what is causing the water heater not to light. there is gas to the pilot but when it goes to light it just goes out. Maybe a safety relay or something?
No such device on the w/h if there was people wouldn't be burning electrical heating elements up. If you have no water in the tank and the burner on your probably setting off the limit turning your burner off.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 03-28-2015, 04:02 PM   #20
There is a thermo couple that might not be positioned correctly or it may be defective. Make sure you light all the burners on the stove to purge the air out of the lines before attempting to light the wh.
pressure, water
