Originally Posted by DAISY BOYKIN
I believe the industry standard is between 40-60 lbs for city water pressure.
City of San Diego
runs between 50 PSI
at the very least (only in a very few areas)
to 100 PSI in (very few) of the higher
average should be prox 75 PSI
at 50 PSI in most Cities
people complain much of low pressure
a regulator is required by code
on all new homes built
or when upgrading
note
pipes and valves used in RV's
are not as strong as
the same used in homes
no comparison
Mountainman
just what was seen in the field
Equip Tec
retired water worked City of SD
