Old 10-25-2014, 11:21 PM   #1
collinpr's Avatar
Water Pressure Question
How much pressure are the water lines good for on a 2014 5th wheel ==365rl ??
Everyone still using the old screw on pressure regulators?
collinpr is offline   Reply With Quote
Old 10-25-2014, 11:31 PM   #2
asquared's Avatar
I still use mine. I'd rather use it and be safe then not use it and oops, too much water pressure blew a line out.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 10-25-2014, 11:51 PM   #3
Just a member
kandl's Avatar
X2 - our FR TT/Fiver Owner's Manual makes no mention of safe pressures for the plumbing. However, the section for winterizing with compressed air is instructive: "Set the pressure to no greater than 30# (pounds)..." We'll stick with the pressure regulator.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 10-26-2014, 12:04 AM   #4
Or you could just pop in an accumulator tank. Keeps high pressure out of your lines and also keeps pressure up when you have a low pressure source. You're pump will run less frequently as well.
rana is offline   Reply With Quote
pressure, water
