Old 03-08-2015, 06:11 PM   #1
Water pressure reducer
Do you need to use a reducer when hooking water to camper
ffemt721 is offline   Reply With Quote
Old 03-08-2015, 06:15 PM   #2
fonzie's Avatar
Most people do 40 to 60 psi setting.
what water pressure regulator (city water) do you use?
Fonzie
Old 03-08-2015, 06:16 PM   #3
You don't HAVE to...but I always do as a precaution.
A leak somewhere inside the walls due to excessive water pressure could be costly !
Black
2014 Ford F250 Lariat SuperCrew 4x4 tuxedo black
2015 Rockwood Signature 8310SS Diamond Edition
***3rd GENERATION EGG FARMER***
***WHO MADE YOUR EGGS TODAY ?
Black is offline   Reply With Quote
Old 03-08-2015, 06:18 PM   #4
Wa11y757's Avatar
Apparently it's better be safe than sorry, Wally World sells a regulator that screws inline with the hose. I think it's set at 40 psi. Super cheap too. I hear some campgrounds can be higher at times trying to make sure everybody has pressure at their site.
2014 Wildwood X-lite 195bh......Happy camping.
Wa11y757 is offline   Reply With Quote
Old 03-08-2015, 06:23 PM   #5
asquared's Avatar
We use the Wal-Mart pressure regulator. Never regretted using. It's very cheap insurance.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 03-08-2015, 06:32 PM   #6
Shinny's Avatar
I've seen the disaster caused by too much pressure and the owners weren't around to turn the water off. We were at the pool in a CG and when we were walking back to our camper, we saw water spewing out of the doomed camper between the floor and wall. Something let loose inside and flooded it. The poor owners were horrified when they returned from sight seeing that day.
I use the WM version and keep a spare, just in case.
2015 Sierra 32QBBS-23 nights camped since the end of June 2014
2015-sorry to say only 11 nights so far, more to come though
Shinny is offline   Reply With Quote
Old 03-08-2015, 07:07 PM   #7
Ddubya's Avatar
I use a Watts adjustable regulator. I found that the less expensive ones cut the water flow.
Ddubya is online now   Reply With Quote
Old 03-08-2015, 08:40 PM   #8
SeaHarley's Avatar
I just purchased this adjustable regulator:
Valterra A01-1117VP Brass Lead-Free Adjustable Water Regulator
from Amazon for $53.41.
Amazon.com: Valterra A01-1117VP Brass Lead-Free Adjustable Water Regulator: Automotive
During our last trip, the water pressure fluctuated from CG to CG. And so did the shower pressure.
So 1 time I removed the cheap regulator I had in-line to get higher pressure.
Without the regulator, the water flow in the toilet was so fast that it swished out and around outside of the toilet - it was that fast.
Too much pressure.
So I quickly reinstalled the cheap regulator.
When I got home, I put a gauge on it and the cheap regulator was measuring 40 psi at the discharge. That is too low.
The new regulator is adjustable and I have it set for 55 psi.
Haven't used it yet. But it will be a lot nicer!
2012 Lacrosse, 308RES.
2013 Ford F150, XLT, 4x4, Supercrew, Eco-Boost.
Lee, Dawn and "CoCo", the dog!
2015 Overnight Camping Days = 25, States Below:
SeaHarley is offline   Reply With Quote
Old 03-08-2015, 09:39 PM   #9
I use the Valterra regulator mentioned above. Better water flow than the cheap Walmart pressure regulators I tried initially. I have never tried the more expensive Watts models as my Valterra seems to flow just fine.
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2 - 2006 model year Border Collies
Mtelkman is online now   Reply With Quote
Old 03-08-2015, 10:11 PM   #10
GLCM Warrior
Lefty59's Avatar
We do use a pressure regulator...but we also try to remember to turn off the city water whenever we leave the camper for an extended period of time for just that reason (a leak while you're not around can be a disaster). We also kill power to the pump when we leave if we are using the fresh water tank for our supply.
I read a story about someone who flushed their toilet, then left to go grocery shopping. The toilet continued to run until it emptied the fresh water tank completely...overflowing the black tank all over into the unit!! YUK!!
2014 Wildcat 312QBX
2014 Ford F350 SD 4X4 CC LB 6.7L PSD
Bob & Debbie, USAF Retired
Lefty59 is offline   Reply With Quote
pressure, water
