06-26-2017, 12:15 PM
Canadian Member
Water Pressure Regulator Recommendations
I'm considering upgrading our water pressure regulator. We are currently just using a basic Valterra Water Pressure Regulator, but I'd like to upgrade to an adjustable pressure regulator with a gauge so I'm looking for recommendations.
They seem to range from the Valterra brass model to a Watts model from RVWaterFilterStore.com.
I'd appreciate some opinions on various models. If you have one of the Watts models, do you have the stainless steel parts or gauge?
Thanks.
06-26-2017, 12:30 PM
I have the Watts 263-A non stainless. It is 9 years old and still works great. The valterra would probably serve your needs as would a Renator. Can't believe the difference on Amazon for Canadian dollar. Even considering the exchange rate the Valterra is 11 US dollars higher on the Canadian Amazon site.
You can avoid reality, but you cannot avoid the consequences of avoiding reality – Ayn Rand
06-26-2017, 05:22 PM
King of the Road
I use this one from Amazon, works perfectly, never a problem. It's also adjustable up to 160psi.
I use the oil filled gauge model
https://www.amazon.com/Pressure-Regu...regulator&th=1
2016 Crusader Lite
Single slide
2013 Ram 2500 Crew Cab Tow Vehicle
2016 days camped = 91, 2017 days camped = 109
06-26-2017, 06:57 PM
So how does one know what to set it to? Wait for a hose to blow?
06-26-2017, 07:10 PM
Most all R/V water pressure recommendations are 55 p.s.i.
06-26-2017, 07:16 PM
I use a non adjustable one which regulates to 50psi. I'm not interested in going higher than that and if I happen to leave it, it's cheap to replace.
-- My wife complains I never listen to her. Or something like that.
2017 Heritage Glen 368RLHBK Limited
2017 Ram 3500 4x4 Crew, 6.7 Cummins
06-26-2017, 07:22 PM
King of the Road
Yeah sure that would be the way you should do it. The rest of us will just do a little reading.
2016 Crusader Lite
Single slide
06-26-2017, 07:25 PM
I have used the Valterra adjustable brass one for about 4 years now. Works great and I have had no issues with the amount of water flow available. The Watts are likely nicer, but in my opinion it is a bit of a diminishing returns situation.
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2006 model year Border Collie
06-26-2017, 07:27 PM
The Valterra I use has a gauge on it.
06-26-2017, 08:34 PM
I use a Renator M11 that I bought from Amazon. It is adjustable. I used to have one that you could not a adjust and it was preset to 40 psi. I can now adjust our pressure to 5o psi. It made a big difference with our water pressure.
2016 Forest River Wildcat 314BHX
2019 Ford F-450 Limited DRW 6.7 Diesel
06-27-2017, 12:29 PM
Many of those "factory set" regulators (non-adjustable), assume an input pressure. If the water system, to which you'e connected has less than the assumed pressure, you are not getting 50psi out of it.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
06-27-2017, 12:34 PM
That's true whether they are 'factory set' (non-adjustable) regulators or ones you can set.
They are regulators, not pumps.
If the incoming pressure is lower than the set level of the regulator, it will be whatever that pressure is.
06-27-2017, 02:13 PM
Dano1955 has your answer. Looks to be very similar to the Valtera you posted.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
06-27-2017, 02:21 PM
I set mine so that the water in the toilet does not splash out when I hit the pedal. Works for me. No idea what the pressure is.
2013 Flagstaff 831FKBSS
06-27-2017, 02:53 PM
2016 Flagstaff 23LB
06-27-2017, 03:23 PM
Just as confused as you
I have to do the same, if I set for more than 45 PSI the water from one of the holes on my toilet will shoot over the bowl.
This is true, but with a regulator that has a gauge, the gauge will stop at the pressure of the water system.
Richard & Jill
06-27-2017, 03:30 PM
Yes, I understand that. However, if the assumed input pressure is 120psi and the output is 40psi, if the input pressure is less than that, the output pressure will be less, also.
A lot of what are sold as "regulators" are simply reducers. They reduce the pressure by a set amount. A true "regulator" will maintain a set pressure-out, as long as the pressure-in is at least as high as the selected pressure-out.
Ben and Doreen
06-27-2017, 06:37 PM
I made an adjustable regulator with gauge from parts I got at Home Depot. I've been using it for years.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost (Best tv ever)
2018 F250 Lariat (ok but I miss my F150)
Getting old ain't for wimps!!!
06-27-2017, 06:55 PM
Speaking about water pressure......... Years ago, most RV manufacturers would test their water plumbing at 100 psi for leaks, but I don't know if they still do. Even then, I would not go over 50 psi. I have helped too many fellow RVers clean up their "flood" when a pipe broke. I always recommend that people turn off the water supply when they leave their RV for a time.
For comparison, I run my stick-built house pressure at 80 psi, and that's with all copper plumbing with soldered joints and no bouncing along roads.
06-30-2017, 09:05 PM
Previous and current owners manual recommend 40 psi, we haven't had a leak yet. Read your owners manual.
DJsFolly
