Old 04-11-2018, 02:22 PM   #1
MacDR's Avatar
Water Pressure Regulator
Just wanted to let everyone know that I increased the water Pressure from 45 psi Pounds to 60 psi on my 2014 340RK without an Issue... I noticed that my Pex plumbing is rated for 150 psi this winter. The extra Shower Pressure was worth the 38.00 investment. FYI I used a Renator M11-0660R Brass Water Pressure Reducer with Gauge.
2013 Ram 2500 "Cummins"
2014 Columbus 340RK
Day's Camped 2018 "32"
You can find us: CrockeryCreek RV Park, MI 9/29 - 10/1
MacDR is offline   Reply With Quote
Old 04-11-2018, 02:31 PM   #2
I have had 110 psi on my RV for weeks at a time with no issue. Iím not saying you shouldnít keep an eye on your water pressure and keep it at a more reasonable level than 120 psi, but worrying about the difference between 40 psi and 60 psi is really not necessary.
Bruce
Old 04-11-2018, 03:04 PM   #3
MacDR's Avatar
I'll try going up a bit more my next trip.. I thought a 50% increase was a good starting point. I'll probably max out at 80psi though. I'm not worried about the
Pex, just the fittings and fixtures.
2014 Columbus 340RK
Old 04-11-2018, 03:07 PM   #4
It's never the PEX tubing you have to be concerned with at high pressures.
The inexpensive plastic fittings/couplers/elbows/faucets will fail long before you see anything from the PEX.
Days Camped: '16=46 '17=30 '18=51 '19=53
Old 04-11-2018, 03:08 PM   #5
We experienced low water pressure on our maiden voyage.
Did the usual fire drill trying to find the source. I had used one of those cheap regulators.
Turned out the camp pressure was low. DUH No one warned me of that.
Getting a new regulator with a gauge..
tomkatb is offline   Reply With Quote
Old 04-11-2018, 08:05 PM   #6
The gauge is an important component to knowing what you are dealing with.
I've been in far more campsites with low pressures than those needing pressure reduction.
pressure, water
