The problem. . . I found the little cap piece on the ground. However i coukd not get the darn hose off do i pulled it out and took it off and looked from the inside. Tapoed a couple times and the white piece came out. I think because the cap popped off it was causing it to hit the connection in the trailer hose, therefore cutting off the water pressure.
Thank You!!
Nowto figure how to get the metal hose connector piece off to put it back in where it belongs.
I have it off right now. Is that ok for the time being? Or will it not work right? Right now we have water.
It is about a hundred degrees out and no shade so i need to wait to try to get it off.
Any suggestions to get it off? When i try to turn the hose, the part it is screwed into turns as well.
How it was. . .
How it should be. . .
