Old 02-18-2016, 06:35 PM   #11
Peytonlover_18's Avatar
Actually I disconnected city water today and tried it, it worked BUT when city water is connected it doesn't work. Any ideas on that?
Peytonlover_18 is offline   Reply With Quote
Old 02-18-2016, 06:45 PM   #12
AquaMan's Avatar
Too much pressure in your city water line keeps the pump from kicking on.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 02-18-2016, 06:49 PM   #13
It just dawned on me when we had our last cold spell, our water pressure regulator froze and I haven't taken it off bc our spigot is all wrapped and tapep up. So I guess or hope that's it. I'll take it off tomorrow and see. Thank you so much!
Old 02-18-2016, 06:50 PM   #14
northstar1960's Avatar
the pump won't come on when using the city water
northstar1960 is offline   Reply With Quote
Old 02-18-2016, 07:15 PM   #15
Correct. With city water connected it won't come on.
Old 02-18-2016, 07:21 PM   #16
AquaMan's Avatar
Let us know how it turns out! Always love a solution!
Old 02-19-2016, 11:45 AM   #17
It's designed that way . when on city water the water pressure keeps the pump from coming on . there is a pressure switch in the pump that shuts it off when set pressure is reached . . you should only have the pump turned on when not connected to city water . then it will draw from your fresh water tank .
Old 02-19-2016, 01:00 PM   #18
Ok, I took off my regulator that's shot and still the water pump won't work with city water connected. So, until they send me a new one (bought a 2 year protection plan) I won't know if the city water pressure is too high. Because isn't that what you or someone mentioned could be it, if not what could it be??
Old 02-19-2016, 02:15 PM   #19
AquaMan's Avatar
With the city water hooked up, why would you even need the pump to work? The pump is a demand type system, where if there is a demand for water the pump will kick on. If the city water is hooked up, there is never a demand for the pump to kick on. I'm not sure what your problem is.
Old 02-19-2016, 02:23 PM   #20
Maybe you need to hear this more then once . no water pump in any rv will work with city water hooked up and on . shut the city water off relieve pressure then your pump should work . It will pump from your fresh water tank if you have water in it . the pump does not pump city water , City water has it's own pressure
pump, water, water pump
