Old 10-11-2016, 09:24 AM   #1
2016 Rockwood 8325SS
Water pump!
This is the first time camping without full hook-up. When I turn the water on the pump sounds as if there is air in the line. The best I can describe what is going on is a machine gun effect coming from the pump. The water is there both cold and hot and is running fine. Just wondering if anything is going on?
Barstorm is offline   Reply With Quote
Old 10-11-2016, 09:28 AM   #2
bubbles's Avatar
Yes. What is going on is that your pump is working. Not an issue.
Old 10-11-2016, 09:37 AM   #3
Wobbles's Avatar
Find the pump. Mine was behind a removable panel. Watch it with a flashlight as someone else runs some water. Look for an extra length of hose vibrating against something. If found you may want to shorten or secure it somehow.
If you do not see any hose vibrating consider remounting the pump to the floor with some sort of insulator. Members have used a a cut up mouse pad between the pump and floor. I did it and it has taken about 75% of the noise away.
search for "mouse pad" fix, in the forum search.
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
Wobbles is online now   Reply With Quote
Old 10-11-2016, 01:42 PM   #4
Moderators' Assistant
bikendan's Avatar
Yep, vibrating water lines are usually the cause of the noise.
Ours were up against the veneer side of the cabinet.
Zip ties pulled them away and problem solved.
Dan-Retired Firefighter/EMT
2016 PrimeTime TracerAIR 255, pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 10-11-2016, 01:57 PM   #5
Sunseeker 3010DS
if the pump is making noise when you have all the valves closed it is sucking Air. if it only makes noise when water is running I agree with the other posts. Most likley hose or pump mounting issue
slamac is offline   Reply With Quote
Old 10-11-2016, 02:30 PM   #6
bubbles's Avatar
The question was, is it normal? The answer is yes. That's the way these cheaper pumps operate. They pulse. If you can hear it loudly then the afore mentioned reasons is why.
Old 10-11-2016, 02:38 PM   #7
I'd like to know a little more before I give the "all is normal" sign.
The OP said it makes noise (like a machine gun) when turned on.
That 'could' be normal.
The OP also said there is water at both hot and cold taps.
That is normal for sure.
What we don't know is, with the switch on and once the system builds pressure, (all faucets closed) does the pump shut off? If the pump continues to run and continues to make the machine gun noise... that is NOT normal.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
Days Camped: '15=22 '16=46 '17=8
Old 10-11-2016, 03:14 PM   #8
If possible put a couple of "loops" in the discharge line. This will help to reduce the oscillation on the supply lines. Also, get an accumulator. This will reduce the cycling of the pump.
dmac1951 is offline   Reply With Quote
Old 10-11-2016, 03:19 PM   #9
Briorick's Avatar
Yes, your pump appears to be working fine, and with you stating "this is the first time camping without full hook-up", I am assuming you may have never heard the real sounds that the water pump omits because of being on City water. Just an assumption.
For us, who don't use full hook-ups, this sound is very much the norm. Maybe not as extreme as you quoted. It's when we DON'T hear that pulsating sound...we need to worry.
But as others mentioned there are ways to offset the sound level of your pump vibration noises.
Also, there are times you will get air into your FW tank and it will take a few moments to get the water pressure running smoothly through your faucets. Just some fyi.
Rick & Brian
1 Happy Camper Pup ( Mya )
2017 Salem Cruise Lite 232RBXL
2004 GMC Sierra 2500HD LT 4x4 6.0 / 4:10
The best plans can be of those that happen in the spur of the moment!
Briorick is online now   Reply With Quote
Old 10-12-2016, 07:09 AM   #10
Thanks to all for the replies. Checked on a few things as mentioned in the replies and have come to the conclusion that the pump is acting normal. Just did not know that the level of noise was what it is. Thanks all, lines seem to be acting normal, little vibrations, not what I would call a problem. Water pressure is fine, so at this time I guess it was just myself, that thought there was a problem. As usual, replies came quick, thanks
pump, water, water pump
