Old 02-06-2018, 12:01 PM   #1
Water Pump
Hi folks
I have had issues with the water pump cycling when water is not being used.I have checked the fitting several times.I have had it to the dealer for it once,and it worked right for a day.I cant find any water sitting anywhere.Sorry the camper is a 2016 Shasta Oasis 26rl.Thank you in advance for any help.
PaPaMooseP is offline   Reply With Quote
Old 02-06-2018, 12:05 PM   #2
There is a check valve inside the pump to hold the pressure. If it is worn or has some dirt in it, it will not be able to hold the pressure and will cycle on and off.
Les & Heidi Kramer
2010 GMC Sierra SLE & 2014 Shamrock 23IKSS
Cleveland, OH
cpd1343 is offline   Reply With Quote
Old 02-06-2018, 12:56 PM   #3
raspivey's Avatar
You could also check the outside shower and make sure something isn't open or leaking there.
Old 02-06-2018, 12:59 PM   #4
Any small leak anywhere in the system will allow the system pressure to drop and cause the pump to cycle. That being said, if there are no obvious drips or puddles, I'd suspect the check valve in the pump.
Old- 2002 21 Roo
New- 2015 Shamrock 23 IKSS
TV- 2010 Nissan Titan CC
wharfrat48 is offline   Reply With Quote
Old 02-07-2018, 01:34 PM   #5
If your pump has the clear cover with the wire screen basket inside make sure it is cleaned out. I found plastic shavings in mine when I had the same problem. Cleaned that out and it works fine now.
2016 Ram 1500 Eco-Diesel
2017 Rockwood 2504S
znate80 is offline   Reply With Quote
pump, water, water pump
