When you say will not work what is it not doing? Have you checked your winterization/antifreeze valve. If it is not fully in the summer /in-use position, it will draw in air. Have you checked the small debris filter on the inlet to the water pump. If the unit was not fully winterized, it may have cracked or it may be loose. Do you have a full water tank.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
