Originally Posted by Garbet
We noticed the water pump started running on in our sunseeker 3120 this weekend. Not sure where it's located. R they normally near the water heater area or the bathroom area and would it be on the inside or outside?
thanks in advance
Garry
Garbet,
Were you using the fw tank or hooked to city water connection?
If you were using fw tank and pump ran for no apparent reason you most likely have air in the system .
Pump should not run using city water connection. Nor should you need it on when using city water connection.
Unless someone turned on switch for pump.
Pump is normally near city water/fw fill location on the inside of coach.
Panels may need to be removed to access it. There most likely is a water filter nearby.
Ron
