Old 10-30-2015, 02:06 PM   #1
Water pump
2013 palimino sabre 5th wheel.
Mike48413 is offline   Reply With Quote
Old 10-30-2015, 02:11 PM   #2
My question is, I am trying to winterize my fifth wheel when I turn on the pump there's very little sound just a humming. It is not drawing any antifreeze through the pipes. Am I doing something wrong?
Old 10-30-2015, 02:11 PM   #3
Fulltime family RVer
Water pump
(deleted)
Old 10-30-2015, 02:12 PM   #4
Are you trying to draw from the fresh water tank or through the antifreeze inlet?
Iwritecode is offline   Reply With Quote
Old 10-30-2015, 02:13 PM   #5
Have you switched the winterization vavles to pull from the exterior port?
And, the other issue I have seen is that the jug of antifreeze can't be too far below the inlet. The pump can't suck it vertically too far.
And, it takes a bit of time to prime the pump.
Old 10-30-2015, 02:15 PM   #6
I had mine suck the AF from a bucket on the ground with no problems. You have to actually open a facet to get it to work though.
Old 10-30-2015, 02:16 PM   #7
Interesting. I read of people having issues with a Sabre, so I just put my AF onto a table first.
I don't think I knew of the faucet. Though, my wife was inside doing just that.
Old 10-30-2015, 02:16 PM   #8
Antifreeze inlet
pump, water, water pump
