Old 04-27-2014, 02:47 PM   #1
iluvlcy's Avatar
Water pump and city hookup
If i fill fresh water tank and run pump while hooked to city water will we have better water pressure ,like for shower? Or does it not work like that?
Pam & Don
2003 Ford Expedition EB
2011 Rockwood 2304s
108 days camped 2013
74 days camped 2014 so far
iluvlcy is offline   Reply With Quote
Old 04-27-2014, 02:56 PM   #2
2014 XLR 27HFS
dave961's Avatar
Not a good idea, in my opinion. If you put more than 40# pressure in the lines you will blow something and have a mess, a tough repair - probably both.
Dave & Audrey
dave961 is offline   Reply With Quote
Old 04-27-2014, 02:57 PM   #3
Whichever one has the most PSI wins.Most members don't use their pump that way though! Youroo!!
Old 04-27-2014, 07:08 PM   #4
Explorer
Yes, I use both on the occasion that the city water pressure is low. Your camper water pump has a pressure shut-off and senses the in house line pressure so it should never put more pressure in the lines than its rated for. The other one that I have seen more frequently is low flow and the camper pump will make up for that too. You should always be using a regulator on the city water but a high-flow-regulator will help.
Well that’s what I do anyhow, seems to work
John
John
2011 Wildwood T26BHXL
2004 Yukon XL Denali
43yrs of camping; one lucky guy
YoungKopernik is offline   Reply With Quote
pump, water, water pump
