Old 04-24-2015, 03:32 PM   #1
Question water pump and filter
Does anybody know where the water filter and the bypass valve for the water system is located in a 2015 Rockwood signature 8280ws fifth wheel?
hcananda2
Alberta
West Country
Booker01 is offline   Reply With Quote
Old 04-24-2015, 03:36 PM   #2
TURBS's Avatar
Look behind water heater for by pass valves.
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Old 04-24-2015, 03:42 PM   #3
thanks for the info,found the water heater bypass at the hot water tank but still searching for the water filter and the water pump, any more ideas?
hcananda2
Alberta
West Country
Old 04-24-2015, 03:48 PM   #4
TURBS's Avatar
Where do you put fresh water in @?
TURBS
Old 04-24-2015, 03:54 PM   #5
driver side, to the rear of the storage bin (basement).Looks like the furnace will be closest thing the storage then all the water fill connections. Inside the trailer just the entertainment unit. Maybe I'll have to take off what looks like a cold air return vent and poke around behind that.
hcananda2
Alberta
West Country
Old 04-24-2015, 03:56 PM   #6
TURBS's Avatar
Flagstaff Likes to hide them behind false panels or a door that's screwed shut but hinged on one side.
TURBS
Old 04-24-2015, 03:57 PM   #7
TURBS's Avatar
My flagstaff access was about a 10x10 door near the floor
TURBS
Old 04-24-2015, 04:00 PM   #8
Thanks for that, will head back in with some tools and start doing some serious investigating, was hoping this would be easy, should have known better,LOL
hcananda2
Alberta
West Country
Old 04-24-2015, 04:01 PM   #9
TURBS's Avatar
Can you put some water in the tank then turn pump on?
You should be able to hear it.
TURBS
Old 04-24-2015, 04:01 PM   #10
will take some pics and let you know what I found.Thanks for the help
hcananda2
Alberta
West Country
Old 04-24-2015, 04:02 PM   #11
TURBS's Avatar
Np !
Good luck!
TURBS
Old 04-24-2015, 04:03 PM   #12
Good idea, but will have to wait for now. Forecast is for 20 F weather for the weekend plus some snow, spring not quite here yet.
hcananda2
Alberta
West Country
Old 04-25-2015, 10:25 AM   #13
Bilcin's Avatar
TURBS is correct. I put water in my fresh water tank and switched on the pump, opened kitchen faucet, pump came on and followed the sound to my closet in the kitchen cabinate. Found an access panel held in by 2 screws. The pump was also located on the inside of where the inlet is to fill the freshwater tank from the outside. Hope I didn't just confuse you, as it sounds weird the way I explained it.
Bill & Cindy McKenna
Philadelphia PA
2015 Palomino Puma 32DBKS
2005 Ford Excursion 6 liter Turbo Diesel
Bilcin is offline   Reply With Quote
Old 04-25-2015, 12:32 PM   #14
I have a 2016 8286ws. And mine is located behind a panel in the pass thru compartment on the driver side. Right where the city water connection is.
njcamper is offline   Reply With Quote
Old 05-02-2015, 10:12 AM   #15
Found the water pump/filter. Hidden behind a speaker that was hidden behind a grill that was under the entertainment center. Almost accessible for someone who has 48 inch arms and a 12 in chest. Looks like I will be doing some plumbing rearrangements so i can access this through the basement.
hcananda2
Alberta
West Country
pump, water, water pump
