Old 04-24-2015, 03:32 PM   #1
Question water pump and filter
Does anybody know where the water filter and the bypass valve for the water system is located in a 2015 Rockwood signature 8280ws fifth wheel?
hcananda2
Alberta
West Country
Booker01 is offline   Reply With Quote
Old 04-24-2015, 03:36 PM   #2
TURBS's Avatar
Look behind water heater for by pass valves.
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Old 04-24-2015, 03:42 PM   #3
thanks for the info,found the water heater bypass at the hot water tank but still searching for the water filter and the water pump, any more ideas?
hcananda2
Alberta
West Country
Old 04-24-2015, 03:48 PM   #4
TURBS's Avatar
Where do you put fresh water in @?
TURBS
Old 04-24-2015, 03:54 PM   #5
driver side, to the rear of the storage bin (basement).Looks like the furnace will be closest thing the storage then all the water fill connections. Inside the trailer just the entertainment unit. Maybe I'll have to take off what looks like a cold air return vent and poke around behind that.
hcananda2
Alberta
West Country
Old 04-24-2015, 03:56 PM   #6
TURBS's Avatar
Flagstaff Likes to hide them behind false panels or a door that's screwed shut but hinged on one side.
TURBS
Old 04-24-2015, 03:57 PM   #7
TURBS's Avatar
My flagstaff access was about a 10x10 door near the floor
TURBS
Old 04-24-2015, 04:00 PM   #8
Thanks for that, will head back in with some tools and start doing some serious investigating, was hoping this would be easy, should have known better,LOL
hcananda2
Alberta
West Country
Old 04-24-2015, 04:01 PM   #9
TURBS's Avatar
Can you put some water in the tank then turn pump on?
You should be able to hear it.
TURBS
Old 04-24-2015, 04:01 PM   #10
will take some pics and let you know what I found.Thanks for the help
hcananda2
Alberta
West Country
pump, water, water pump
