Old 06-08-2013, 09:36 PM   #1
Water Pump Fuse
Hi everyone. I have a 2010 Forest River Shamrock 19 and the water pump stopped working. Pump got really hot because it was left on and valve was off. derp... I pulled the pump out thinking I would replace it, but thought I would try it hooked directly to a battery. Pump seemed to work fine. Since there is no power at the pump wiring, I'm thinking a blew a fuse. Fuse in the panel are all good. Question is if anyone knows if there is and inline fuse and where it is out. Looked under the rig toady and saw nothing. Nothing I would see by the pump either. thanks in advance. Sam in AZ
samcut is offline   Reply With Quote
Old 06-08-2013, 09:52 PM   #2
Iggy's Avatar
Water pump fuse should be really close to the pump itself.
Mine is different but you can see the fuse inline.
Name:	Motorhome Home 015.jpg
Old 06-08-2013, 10:00 PM   #3
Thank you! I'll check it out tomorrow. I didn't see anything like that, but I might have missed something. Sam
Old 06-11-2013, 12:09 AM   #4
no luck
I did not see a fuse by the pump. Guess I'll keep hunting around!
Old 06-11-2013, 12:14 AM   #5
Iggy's Avatar
If you have a control panel or switch on the wall it may be behind it.
If it is justr a wall sswitch that's easy enought to reove and pull the wires to see the splices. Worth a try
Old 06-12-2013, 10:00 PM   #6
Found it! It was behind the switch in the wiring. Had to pull all the wire out to find it. Why in the heck they do this is beyond me. thanks!
Old 06-14-2013, 11:00 PM   #7
bikendan's Avatar
samcut, next time you may want to post in the Roo or Shamrock sub-forum, especially involving questions specific to your model, like where the pump and its fuse are.
things like that, vary from type and model of RV.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
