Old 07-03-2016, 08:22 PM   #1
2006 Georgetown 340
Smile Water Pump Growl
We have had our 2006 FR Georgetown for about a year. During this time we always noticed the water pump makes a growling sound whenever the sink or toilet or any water need is used. When the water shuts off the pump shots off and the growling stops. My question is does anyone else have this? Is it a sign the pump is going out? Should we be concerned?
Thanks in advance.
Rich
compint is offline   Reply With Quote
Old 07-03-2016, 08:31 PM   #2
That is Normal,if you want it to stop have a Big Pressure tank installed! Youroo!!
Old 07-03-2016, 08:46 PM   #3
northstar1960's Avatar
you may want to look and see how they have it mounted . sometimes it could be set up against a panel or something similar causing excessive noise when running . make sure the mounting screws are tight also . not uncommon to have a pump make way more noise because of poor mounting A pressure tank will allow you to use some water with out the pump turning on all the time but once the tank is empty to the low psi point the the pump will run till you done with use and the tank fills back up
northstar1960 is offline   Reply With Quote
pump, water, water pump
