Old 08-16-2016, 09:51 PM   #1
Water pump in 2250 sunseeker
I had my water heater worked on today...drained and anode replaced. Now when I turn the water pump on it sounds like it is pumping from the heater. I know the fresh water tank is low. HELP
wvalady is offline   Reply With Quote
Old 08-17-2016, 04:18 AM   #2
ilmor's Avatar
Sounds like your water heater needs to fill up. Are you getting water from both hot and cold side of faucets?
OR...when the water heater was worked on the winter bypass valves were messed with and not put back as they belong?
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
pump, sunseeker, water, water pump
