Old 06-24-2017, 10:25 AM   #1
Water pump issue
Am at a RV park hooked up t0 city water. Just happened to look at the tank indicators and noticed my fresh water tank was full. Almost overflowed. I turned off the city water and turned on the water pump. Am now using the water pump and fresh water tank. Is this a water pump issue? I have a 2015 Saber.
jrmorris is offline   Reply With Quote
Old 06-24-2017, 10:32 AM   #2
A32Deuce's Avatar
There is a check valve that stuck. If you turn off the pump and city water back on, should be OK. If not maybe dirt in check valve. Heard of this from several others.
A32Deuce is online now   Reply With Quote
Old 06-24-2017, 10:41 AM   #3
Agree with Deuce, also what is the Water Pressure at the C/G? Are you using a Pressure reducer? This can be answered with a "Yes or No"! Youroo!!
Old 06-24-2017, 08:00 PM   #4
Thanks. I had turned the city water off and used the water pump. When I got the answer that the water pump check valve may have stuck I then turned the water pump off and city water back on. Seemed to work. We then took off exploring the Breckenridge Colorado area and just returned to find you reply. Thank you and yes I do use a pressure regulator. Am monitoring the fresh water tank and so far so good. Thanks again, John
pump, water, water pump
