Old 11-08-2017, 07:58 AM   #1
water pump issue
Pump works when pulling water from fresh water tank. For the past 3 years it will not draw antifreeze from the bottle and I have to use a funnel and pour antifreeze into line. Any thoughts?? Thanks.
2010 Flagstaff 8528RKWS
2009 GMC 2500
tom.keith is offline   Reply With Quote
Old 11-08-2017, 08:24 AM   #2
Have you verified the winterizing valve is working?
Did you remove the line at the pump to see if antifreeze is even getting to the pump?
What happens once your pour antifreeze into the line?
Days Camped: '16=46 '17=30 '18=51 '19=36
Old 11-08-2017, 08:28 AM   #3
jeff64's Avatar
Maybe the difference in suction lift height(head) from the ground level vs. the potable tank. Maybe? I ran into this on a friends TT. I set mine on the 3rd step of a ladder approx. level with floor. it seemed to prime ok. Did the water system seem to function o the last time you were out. ie shutting off, pressurizing the lines etc
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 11-08-2017, 08:34 AM   #4
Witch Doctor's Avatar
Check to see if you have a shut off valve on the fresh water tank, I have one and had to close it, otherwise you can't pull the AF. In, I couldn't figure mine out til I found that valve and shut it.
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-08-2017, 08:54 AM   #5
Flybob's Avatar
You don't say where you are sitting the antifreeze bottle. Try sitting it on something so it is close to the level of the pump. Make sure the winterizing valve ( on antifreeze line is ) is set correctly.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-08-2017, 01:58 PM   #6
Thanks for replies. My set up has me unscrew the feed for fresh water tube at the pump and screw in a 2 foot siphon tube which I place into a gallon jug of anti-freeze that sits on the floor/same level as my pump. Pump runs but does not "pull" anti-freeze from jug. When I poor anti-freeze into tube via funnel the pump distributes the anti-freeze.
2009 GMC 2500
Old 11-08-2017, 02:02 PM   #7
Once the pump is primed (by pouring the antifreeze into the line, can you then place the line in the jugs and it siphons and pumps OK?
Old 11-08-2017, 02:39 PM   #8
Just as confused as you
Scrapper's Avatar
I have a 2.5 gallon cat litter jug I fill and set it on the ground. The top of the jug is about 2 ft below the AF connection on the TT. It takes about 30-45 seconds til I hear the pump prime then another 30-45 seconds for the AF to come out the farthest opening which is a low point drain. I had to cycle the pump on and off once or twice when I winterized this past October, I think the pump was stuck.
Richard & Jill
Camping since 1989, seasonal since 2000
pump, water, water pump
