Old 05-01-2012, 06:01 PM   #11
Herk7769's Avatar
Originally Posted by TRAVLINOHIO View Post
Pumps working, I found a loose wire on the pump. Plugged it back in, and it worked fine, still cant find the valves for the water heater?? Looked behind both access panels, not outside trailer?? Gonna stop at dealer tomorrow and ask.
Should be located directly opposite the metal cover on the outside; but on the inside.
HAM CALLSIGN - KC3FFW
Old 05-01-2012, 06:10 PM   #12
Malco's Avatar
I have a 2011 30kqbss.The valves are under the sink.If you open the door under the kitchen sink and look to the right on the bottom shelf there is a thin panel.the panel is very flexible and can pull towards you.Do this and there are 3 valves .Open the top and bottom ones and close the middle one.
2011 Salem 30kqbss
2013 Ram 2500
2005 Ram 2500
1968 Pontiac Le Mans
Malco is offline   Reply With Quote
Old 05-01-2012, 06:49 PM   #13
Thanks for all the help! Found them!
Steve
13 days reserved in 2012 so far!!
TRAVLINOHIO is offline   Reply With Quote
Old 05-01-2012, 08:04 PM   #14
Herk7769's Avatar
I removed that panel and several others. They may block ugly wires and pipes but they also steal your most precious commodity. Storage space.
