Old 12-29-2015, 01:32 AM   #1
AMG
Water pump issue on 2016 FR TH
I am under warranty, but wanted to know if anyone has any ideas on this issue and perhaps if I can fix it on my own because it may be a stupid problem.
2016 FR Stealth WA2916. When I am dry camping, I turn on the faucet in the kitchen for example and it barely trickles out (both hot and cold). I hear the water pump kick on but it is a light hum. I can let the sink run for 30 seconds and nothing changes. I then turn the sink off and the water pump continues to just lightly hum and still no water pressure. If I go to the bathroom, turn on the sink there, turn on the kitchen sink, and then hold the flush on the toilet down, you hear the pitch of the water pump deepen and work hard, then I turn the bathroom sink off and stop the toilet (via the foot depressor) and the kitchen sink then has nice pressure. I turn the sink off and the water pump within a couple seconds get deep tone and stops. At some point later, yes the problem reoccurs.
I also noticed that the water pump will just run, hour after hour with the light hum, not stop. It's hard to realize it if you have the stereo on, or watching a movie and someone turns the sink on quickly, but that issue above occurs, and the pump just never stops and never gets that deep ticking before turning off.
Sorry if that's difficult to convey in words.
TH : 2016 Stealth WA2916
TV : 2012 Ford F-250 PSD
AMG is offline   Reply With Quote
Old 12-29-2015, 04:46 AM   #2
Witch Doctor's Avatar
It sounds like your water pump is not holding it's prime. They are self priming. And the hum is probably trying to prime. You might have to pull off the front part of the pump off and make sure the rubber diaphragm are seating or not cracked.
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 12-29-2015, 05:14 AM   #3
Issue with the (Input/Suction) side of the Pump. Loose connection anywhere from the Pump back to the F/W tank! Kink in the Hose or Pre filter screen full of Crap! Just a WAG! Youroo!!
youroo is online now   Reply With Quote
Old 12-29-2015, 06:31 AM   #4
TURBS's Avatar
Air in the system.
Old 12-29-2015, 10:35 AM   #5
AMG
Originally Posted by TURBS View Post
Air in the system.
I've wondered the same thing actually. I have ran all the faucets and the toilet multiple times on trips, for countless gallons. I could bring the trailer home, and just fill up 160g and then turn them all on and let it move all the water through it? Then ensure that I never, ever release any water out of the system, for fear that some air could get in? Never undo the low-point hot/cold drain, etc.
But maybe the air is coming in some other way then? Even though water pressure is crazy low and the pump often just runs, there isnt burping air coming out of any of the fixtures.
Old 12-29-2015, 10:46 AM   #6
fonzie's Avatar
If you have an anti-freeze inlet valve, make sure it is set properly to fresh water tank....
Name:	water pump and anti-freeze valve hok up.jpg
Fonzie
Old 12-29-2015, 10:48 AM   #7
Pickin' & Campin'
I agree.
I've had two units where the suction filter simply unscrewed far enough out of the pump (from vibration I presume) to where they sucked enough air at the threads to loose prime but didn't leak. I'd check there first.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 12-29-2015, 10:50 AM   #8
Pickin' & Campin'
And make sure you hose isn't kinked like the one in this picture!
Old 12-29-2015, 11:47 AM   #9
I had a problem like that it turned out that the water filter ring had a small crack and pump could not get up to pressure.
mustardjim is offline   Reply With Quote
Old 12-30-2015, 01:47 PM   #10
I also had the same problem, turns out the diaphragm was stuck.
Avan is offline   Reply With Quote
pump, water, water pump
