Old 04-25-2015, 06:47 PM   #11
Are you sure you have water in the fw tank? Could it be possible the hose from the tank to the pump has a hole in it or has come loose from the tank? If the pump will pull from a jug, then it has to be something is amiss on the tank side.
Old 04-25-2015, 06:47 PM   #12
fonzie's Avatar
Do you have enough water into the fresh water tank?????
Fonzie
Old 04-25-2015, 06:48 PM   #13
fonzie's Avatar
OK you beat me to it
Fonzie
Old 04-26-2015, 11:29 AM   #14
Look at my link this was my problem today Water pump pulling air issue resolved
The black inlet filter (metal screen) was not screwed on the whole way - felt okay but then I was able to turn it two more times and then I was able to get no air. It looks like its part or the pump but it does screw on or off, they just never screwed in on completely.
2006 Honda Goldwing
2012 Toyota Tundra DC
2015 Cherokee Grey wolf 19RR Limited
bluewoo is offline   Reply With Quote
Old 04-26-2015, 12:29 PM   #15
Makin' Life Simple
skisteveski's Avatar
Am up and running now fellas thanks for the tips. It was the gasket on intake
skisteveski is offline   Reply With Quote
Old 04-26-2015, 04:09 PM   #16
Thats great
2006 Honda Goldwing
pump, water, water pump
