Old 08-18-2010, 12:15 PM   #1
skeeterbait8's Avatar
Water pump kicking on?
We have looked and looked for any sign of a leak, so far can't find anything. That is my first thought, we must have a leak! But then hubby is wondering if many it isn't just the nature of the beast. What is happening is that our pump will kick on, just for a split second, every so often. I say leak that we have not found yet. Your ideas?????
Official member of the "Roo Kroo"!
2009 - 4, 2010 - 135
2011 - 95 and counting
skeeterbait8 is offline   Reply With Quote
Old 08-18-2010, 12:32 PM   #2
MtnGuy's Avatar
It might just be a little water leaking past a check valve.
Old 08-18-2010, 12:49 PM   #3
IMHO this is a "fairly" normal occurance. It wouldn't take much of a water or air leak to eventually cause the pressure to drop enough to activate the demand pump. In our previous '06 Rockwood 2604 we got into the habit of turning off the pump overnight so that it couldn't turn on while we were sleeping.
...VTX-AL
VTX Al is offline   Reply With Quote
Old 08-18-2010, 03:43 PM   #4
Herk7769's Avatar
RVUpgradeStore - Accumulator Tank
Problem solved.
Also can use bathroom at night without waking DW due to REALLY LOUD water pump.
HAM CALLSIGN - KC3FFW
Old 08-18-2010, 05:27 PM   #5
camping
tentcamper1's Avatar
mine does the same thing, on for a second or two. like mtnguy said could be the check valve, could also be some debris in the check valve and it just needs to be cleaned. I called the factory on this and they are sending me a new pump to make sure that is the problem, if not I will need to bring it in so they can take a look at it to make sure there are no leaks. I checked for leaks during the last trip and found none.
2007 Chevy 2500HD CC
2010 V-Lite 30WRLTS
Nights Camped 2011 -64
Nights Camped 2012 -50
"I Live in My Own World, But It's OK. They Know Me"
tentcamper1 is offline   Reply With Quote
Old 08-18-2010, 05:46 PM   #6
Herk7769's Avatar
I should have also added that a slow leaking check valve would let off enough pressure back into the fresh water tank to trigger the pump for a second or two. The inlet check valve is internal to the pump and replacing the pump is the only fix.
Old 08-18-2010, 06:12 PM   #7
camping
depending on the pump model you can take it apart and clean the check valve or even just replace the check valve. check out your pump manufacturers website. I have a Shurflo pump.
from Shurflo:
Question: The pump runs when there is no demand for water. How can I fix this?
Answer:
1.Purge all the air in the system and check for leaks in your faucets or lines. If no leaks exist, you may have debris in the check valve/switch or valve assembly.
2.Clean debris or replace the check valve or valve assemblies.
2010 V-Lite 30WRLTS
Old 08-18-2010, 06:26 PM   #8
tomjsas's Avatar
I've also been experiencing this lately and mine is the result of the valve in the city water connection failing (this is my second one - first one failed completely and shot water like a fountain!). The pump would cycle for a second every 15 mintues or so. Looked all over for other leaks and then went out and popped the cap and noticed a light dribble from the connection. Instead of replacing the whole thing this time I think I'm going to put a manual bypass valve in the line that I can reach in activate if I am going to hook to city water. Most of my camping is at areas that don't have water hookups so wouldn't be that often and saves pulling the city water connection again.
Tom
Pull-Rite 16K Super 5th
2014 Rockwood Signature Ultra-Lite 8289WS
2011 Chevy 2500HD - DuraMax (Just over 5000 miles now!)
Nights camped in 2014 - 21
tomjsas is offline   Reply With Quote
Old 08-18-2010, 06:56 PM   #9
Herk7769's Avatar
from Shurflo:
Answer:
Thanks! I was given bad info. Sorry.
Old 08-18-2010, 08:11 PM   #10
ours did this brand new on the dealers lot. quickly found out that the low point drain cap on the camper was not on right. something about an o ring was left out or wasnt tight not sure. We looked forever to try and find the leak and finally noticed the little damp area on the gravel. Just keep in mind the leak doesnt have to be inside.
Deleted Account is offline   Reply With Quote
