Old 10-09-2012, 01:35 PM   #1
water pump location
Hi,
Greetings to you all. I am recent owner of a Salem Villa classic 402qbq. I am looking for the water pump. If anyone has or is familiar with this model please let me know, thanks.
Peace to all campers.
kevincoleman37 is offline   Reply With Quote
Old 10-09-2012, 01:46 PM   #2
TURBS's Avatar
Originally Posted by kevincoleman37
Hi,
Hello and welcome to the forum !
I'm not familiar with your unit but you didn't post a year .
Mostly often there hidden in a cupboard or under a seat or behind a false panel.
Normally your pump is real close to where you add fw to the tank and or city water connection.
Turbs
Old 10-09-2012, 02:00 PM   #3
Triguy's Avatar
Try turning on a faucet using the pump and fresh water tank. If its like most pumps, you will be able to hear it and narrow down its location. Like Turbo said, it might be behind a false panel that you can unscrew.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 10-09-2012, 02:01 PM   #4
Originally Posted by kevincoleman37 View Post
Hi,
Put some water in the fw tank and turn a faucet on just a little and listen for the pump. Won't be hard to find. May be a little difficult to get to tho'.
Old 10-09-2012, 02:05 PM   #5
B47
Hi,
As Turbo said, - the water pump in our Silverback FW is located on the left side in the water servicing compartment behind a false curved panel.
If you can't find it, I suggest you have someone turn it on while you are outside the unit. You should be able to hear it when it's running.
Old 10-09-2012, 04:44 PM   #6
pump
thanks guys. it is a new model 2012 or 13. most likely i will turn on the pump and give a listen. i looked in all the obvious places, it must be behind a panel.
