Old 07-22-2014, 09:59 PM   #1
Water pump location on Sierra 360PDEK
Does anyone know the location of the water pump on the Sierra 360PDEK unit. I can hear it running however its not pumping water and the water tank is full. Need the check the pump to see if it picked up some debris.
hollowayr is offline   Reply With Quote
Old 07-22-2014, 10:36 PM   #2
Dave_Monica's Avatar
If you have a docking station, it's probably in the utility area behind it...there should be an access panel that you can remove. Is there a selector switch to chose between city connection and FW tank as the supply?
Dave
cat, location, pump, sierra, water, water pump
