Old 05-22-2014, 03:38 PM   #1
sunnygirl01's Avatar
Water pump on?
OK, so this may be a dumb question but do you have to have the water pump on when you are hooked up to a water supply? We don't normally put any water in our fresh water holding tank. We had the water pump on the other day and it started making this clicking noise. I hope we didn't burn it up. It is sad that we have had our camper for 2 years and we are still not sure of much. We just never have had any experience with them. :-/
Sent from my XT1055 using Tapatalk
Steve and Brandi & our "Pit" crew Bella
sunnygirl01 is offline   Reply With Quote
Old 05-22-2014, 03:42 PM   #2
Mr. Dan's Avatar
No, you don't need your 12v water pump to be on if you are hooked up to running city water.
No, you don't want to turn your pump on when you have no water in your fresh water tank.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 0; booked = 14
Old 05-22-2014, 03:42 PM   #3
You do not need it on when hooked to city water. The pressure comes from the line. As a matter of fact you should use a water pressure regulator as sometimes the pressure can be so high it can damage your pipes.
grubbster is offline   Reply With Quote
Old 05-22-2014, 03:58 PM   #4
Ford Idaho's Avatar
I would go ahead and put some water in the tank now just to check the pump, you can drain it later.
Old 05-22-2014, 04:01 PM   #5
Thanks everyone. That is kinda what occurred to me...after the fact of course. We do have a water pressure regulator on our fresh water hose. The dealership made sure we didn't leave without one
Old 05-22-2014, 04:13 PM   #6
dcheatwood's Avatar
I keep a few gallons in the tank all the time for use when traveling. Flushing, hand washing, watering the dog, etc. 5-10 gals.
Sent from my XT907 using Forest River Forums mobile app
2018 Forester 3011 DS
Old 05-22-2014, 04:18 PM   #7
Iggy's Avatar
It is always good to keep a little fresh water in the tank to be used when you are travelling and not hooked up to any power.
Toilet, sink, etc. I would put a small amount in the tank and run the pump to insure it will pump water.
Good luck
2012 Georgetown XL - 378TS 63K + miles
Iggy is online now   Reply With Quote
Old 05-22-2014, 04:38 PM   #8
Brother Les's Avatar
It is not the best for them, but RV water pumps can be ran dry for a little while. I believe that there is a safety switch on some pumps to shut them down if they over heat, do to a lack of water.
http://www.amazon.com/SHURflo-4008-1...productDetails
can run dry without damage
Brother Les
Old 05-22-2014, 06:06 PM   #9
dcheatwood's Avatar
Good luck
And the pump should turn off after it pressurizes the system. If it does not turn off after a few minutes, check for water dripping somewhere. outside shower, sinks, low point drain, etc.
Old 05-22-2014, 06:31 PM   #10
I must say...this forum, and you all, are the BEST!
pump, water, water pump
