Old 09-30-2012, 04:51 PM   #1
Water pump Palomino 356 QLB
Am I missing something here? I've got my fresh water tank showing 2/3 full on a 100 gallon tank, how long should the pump have to run to get water at faucets and shower.
I just pulled in from our maiden voyage so there should still be water in all the lines.
Thanks, Grant
TheGoodwin4 is offline   Reply With Quote
Old 09-30-2012, 04:53 PM   #2
TURBS's Avatar
I'm assuming you used the pump during your maiden voyage?
Your certain it 2/3 full ?
Turbs
Old 09-30-2012, 05:33 PM   #3
No, actually I didn't. I was connected to city water and didn't even think of trying the pump. I thought that maybe I just didn't have enough water so when I got home I added a bunch.
Old 10-01-2012, 09:37 AM   #4
I cannot imagine it taking very long. On the 27 SBU, it only took about 15 seconds to get some flow. If the pipes were stone empty, it might have taken a minute for the high pressure switch to turn off the pump.
Foard County News & Sassy Schoolmarm
with Lady & Chloe, 2013 39 days, 2014 59 days
2017 GD Imagine 2800BH
'07 GMC Sierra 2500HD Diesel 4x4
Why I got into RVing & More Fun
ng2951 is offline   Reply With Quote
Old 10-07-2012, 09:25 PM   #5
Did some more searching online and found a post on here where someone had the same problem. It was a simple newbie issue of the valve was turned for suction of antifreeze.
Now I need to mess with the lines that are hammering. Anyone ever have this issue?
Old 10-07-2012, 09:54 PM   #6
VinceU's Avatar
If you mean water hammer in the pipes its because you have air stuck in all faucets including outside. Once you bleed everything it will stop.
