Recently bought a used Rockwood Ultralite 8283SS and am having trouble with the water pump. (Everything works fine with city water.)
First, there's plenty of water in the fresh tank and I've check the connections on the pump for tightness.
Sometimes it seems to work fine. Other times you turn the water on and there's nothing but if you wait long enough, (maybe even minutes) then the pump comes on and water flows.
Other times the pump runs (it seems like it may be making less noise though) constantly whether you're calling for water or not. I've even had it come on when no one was in the trailer and no one was using any water at all.
Is this a bad pump, bad water connections, electrical or something else. I'm a relative newbie so please be detailed in any explanations.
Thanks,
