Originally Posted by pmsherman
Please don't forget to post the solution your dealer came up with. Having the solution may help the next owner running into the problem.
Phil
PM, had every intention of doing so; that’s about the only way I can contribute to these boards until I get a little
more seasoned.
Just got home and things are running fine now. Turns out the line from the tank on the inlet side of the pump was not fed under the trailer, through the frame, properly. There’s a notch for the lines that was missed by a couple of inches and I guess they pulled the lines nice and tight, which caused restriction.
Here’s (hopefully) a pic of what came out. Thanks again to everyone for the advice!
