Old 04-26-2015, 10:29 AM   #1
Water pump pulling air issue resolved
Just finally getting the camper ready for next week and I needed to check the fresh water pump to make sure it worked properly and behold it did not,the pump would not shut off and I was getting a lot of air in the system. So decided to start tearing into it and load and behold the metal inlet screen assembly was not screwed the whole way on to the water pump causing it to draw Air, as soon as I reinstalled it and saw how many turns at took i turn the pump on it made pressure in the system was purged in less than 30 seconds.
2006 Honda Goldwing
2012 Toyota Tundra DC
2015 Cherokee Grey wolf 19RR Limited
bluewoo is offline   Reply With Quote
pump, water, water pump
