Old 07-14-2012, 12:23 AM   #1
Water pump question (SOLVED)
Hi;
I know this is a basic question....
As first-time TT owners/users, we went out today to try out the plumbing in our new-to-us Flagstaff 831KRSS. We filled the fresh water tank, put the anode rod back in the water heater, turned on the taps, turned on the pump.... and nothing. The manual says to let the pump run while it fills the hot water tank until water comes out the taps at a steady stream, then turn off the taps, and the pump should turn off automatically. How long should it take for water to come out the taps? We waited a loooong time, and nothing. Does this mean the water pump is broken? Or is there a much simpler, forehead-smack-inducing, explanation?
Thanks in advance!
AB
arctic_bunny is offline   Reply With Quote
Old 07-14-2012, 07:13 AM   #2
Triguy's Avatar
First, did you hear the pump working and are all bypass valves turned correctly?
Assuming the pump was working but not taking up water, than check for a clogged inlet. Also check your fittings to make sure they are threaded correctly and tight and not sucking air. Long shot, but my FW line can be shut off just below the FW tank, too, so check if there is a valve that is closed.
Some pumps will have a winterizing kit that allows the pump to suck antifreeze to fill the lines. Make sure that is bypassed so the pump is set to to take up water from the tank.
I would start there and let us know.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 07-14-2012, 07:14 AM   #3
Herk7769's Avatar
My money is on right there.
HAM CALLSIGN - KC3FFW
Old 07-14-2012, 12:05 PM   #4
Thank you for the responses!
Now, where do I find the bypass?
Old 07-14-2012, 12:16 PM   #5
Herk7769's Avatar
It is not a "bypass" in the same sense as the bypass for the water heater.
It is more like a "selector" and switches from the fresh water tank to a gallon bottle of RV antifreeze through a hose.
In the photo (and believe me when I say that my compartment DOES NOT look this neat) the gallon jug is hooked up to a T valve that is the selector. It should be very close to the water pump.
Name:	Pump Storage Diagram.JPG
Old 07-14-2012, 12:50 PM   #6
Is it possible this is inside, under a closet, and requires a screwdriver to take off the panel?
Otherwise, I've seen nothing like it.
Old 07-14-2012, 12:55 PM   #7
Herk7769's Avatar
In my 5th wheel the basement wall had to come down.
Name:	6 June 2009 025.jpg
Old 07-14-2012, 12:58 PM   #8
Put 1/4" push pins in mine, compliments of some govt agency that flys airplanes.
Old 07-14-2012, 01:50 PM   #9
Herk7769's Avatar
I discovered that with that wall removed I had lots more space.
Most of it never found its way back in. I just use a small section now.
Old 07-14-2012, 02:40 PM   #10
Looks like it is already occupied and not much room for anything else.
