Old 03-21-2015, 09:08 PM   #21
Canadian Member
itat's Avatar
The handle on the valve on the bypass line should be perpendicular to the line and the valves on the lines going into the water heater should be parallel to the lines (opposite of the bypass valve). As long as the valves are set like this it is set properly and you'll have figure out why the pump is drawing air. Before you pull the pump, try to tighten the connections on both sides of it.
itat is online now   Reply With Quote
Old 03-21-2015, 09:31 PM   #22
Canadian Member
itat's Avatar
Here is picture of the valves in the bypass position. Just reverse each valve to allow water into the water heater.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 03-22-2015, 07:35 AM   #23
david345's Avatar
I saw another post with a photo that said close the middle valve( bypass valve). I tried both ways. This morning I made sure the inlet and outlet sides on pump were tight as well as the screen filter. I don't have a filter in the water filter housing. Don't know if that makes a difference but will try that later today
david345 is offline   Reply With Quote
Old 03-22-2015, 08:02 AM   #24
The valves to the inlet and outlet must be open and the bypass valve closed.
Old 03-22-2015, 08:04 AM   #25
david345's Avatar
Here is a photo of my pump tank and valves. At least it's easy to get to. Could someone explain to me what each valve does. Thanks for all the helpClick image for larger version
Name:	ImageUploadedByForest River Forums1427029460.693153.jpg
Old 03-22-2015, 08:05 AM   #26
david345's Avatar
I removed the water filter so you could see the valves
Old 03-22-2015, 08:12 AM   #27
The valves at the tank when open allow water to go into and out of the tank. IF the bypass valve is in the open position with the tank valves open also, the water will take the path of least resistance and you will get very little hot water. IF the valves at the tank are open, the bypass valve should be closed.
When you close the valves at the tank and open the bypass valve, it allows you to put anti freeze in the system WITHOUT having to fill the 6 gal water heater.
Old 03-22-2015, 08:32 AM   #28
david345's Avatar
So the valves in my photo are in the correct position
Old 03-22-2015, 08:36 AM   #29
So the valves in my photo are in the correct position.
Should be if they are functioning properly. Have heard of cases where one or the other were not working correctly, but your water pump or city water should now fill the water heater.
Old 03-22-2015, 08:42 AM   #30
david345's Avatar
City water does fine. The pump just spits air and little water. Won't prime and keeps running
pump, water, water pump
