Old 03-22-2015, 08:44 AM   #31
fonzie's Avatar
Originally Posted by david345 View Post
City water does fine. The pump just spits air and little water. Won't prime and keeps running
You have both valves open on your water pump intake. Close top valve which I think is for anti-freeze. Bottom valve is from your fresh water tank.
Fonzie
Old 03-22-2015, 08:51 AM   #32
Ford Idaho's Avatar
How much water is in the fresh water holding tank?
Old 03-22-2015, 09:04 AM   #33
Flybob's Avatar
Here is a photo of my pump tank and valves. At least it's easy to get to. Could someone explain to me what each valve does. Thanks for all the helpAttachment 71915
You should not have both of the valves on the left open. One is the water intake from the water tank, the other is intake from an antifreeze bottle. You should only have one at a time open. Can't tell from the photo which is which, but close one at a time and try it.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-22-2015, 09:24 AM   #34
No the Pic shows (2) valves Open on the Suction side! Only (1)should be Open to F/W Tank! Youroo!!
Old 03-22-2015, 09:27 AM   #35
Flybob,posted the same! Youroo!!
Old 03-22-2015, 09:30 AM   #36
I should have looked closer, but was concentrating on the water heater only. My bad! (again)
Old 03-22-2015, 11:36 AM   #37
Left Coast
Remember, these are only a quarter turn valve, not like a fauset. (Spell.)
Old 03-22-2015, 12:02 PM   #38
david345's Avatar
This was driving me crazy. Just didn't think about the antifreeze valve. Closed it and now it works perfectly. Pump shuts off and pumps when opening faucet. I can't thank you guys enough. Problem solved
david345 is offline   Reply With Quote
Old 03-22-2015, 12:05 PM   #39
Canadian Member
itat's Avatar
That's what this forum is about. We've all been new to this at one point. Hope everything else is running smoothly. Happy camping!
pump, water, water pump
