Old 07-09-2014, 12:19 PM   #1
BamaBob's Avatar
Water Pump Questions and Discussion
Over the weekend we stayed at a "Redneck Riveria" RV Camp
One thing was apparent: the water pressure was...well..low...really low...low enough that our Oxygenics functioned like a standard cheap-O stock shower head
Over lunch, I chatted with some RVers at work (all engineers of course ) and we started wondering if in cases such as mine it would not be better to upgrade the RV water pump to a higher output pump and use the FWT when camped at a park with low water pressure.
Floor is now open for discussion (away from our 5er, I cannot even open the door and tell you WHAT pump FR uses in the Rockwood 5er series )
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
BamaBob is offline   Reply With Quote
Old 07-09-2014, 12:21 PM   #2
dcheatwood's Avatar
I've always thought that I'd upgrade when original goes out. Would solve pressure problem.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 07-09-2014, 12:33 PM   #3
Toby's Avatar
Wouldn't that mean you'd also fill your GWT and drain your FWT even faster than before? That's what I would be worried about.
2018 Ford F250
2019 Arctic Wolf F295QSL8
Toby is offline   Reply With Quote
Old 07-09-2014, 12:34 PM   #4
Kaadk's Avatar
Why do you need to upgrade the existing water pump? Couldn't you just use the low pressure to fill the FW tank and use it as normal?
There's no use crying over spilt milk, unless it's on your keyboard.
Old 07-09-2014, 12:40 PM   #5
BamaBob's Avatar
I feel the same way...and I have a sneaking suspicion that Rockwood is already using the Sureflow 3GPM pump (will confirm when I get home )
One thing: a colleague dropped by to mention is to look in to installing an accumulator - he said this would keep the pump from constant on/of cycling. I ned to look into that perhaps!
Old 07-09-2014, 12:47 PM   #6
dcheatwood's Avatar
Not sure why you'd fill gray tank any faster than on city water unless you mean more pressure means more water.
I think the op is trying to get enough pressure to have a nice shower and city pressure was low and current pump is not pressurizing enough.
I'm just gonna stick with what I have and replace with larger pump when this one goes out. I see his thought process here and have considered it myself.
I seldom dry camp so filling the gray tank fast is not an issue for us. I sometimes leave it open and draining until the day before we leave, then close it to catch some "rinse" water.
Old 07-09-2014, 12:55 PM   #7
Toby's Avatar
I guess so. More times than not I'm camping with no hookups except electric so pumping more water through means go through resources faster/sooner. If you have full hookups all the time then it's all moot. I've never used the pump with city hookups either.
2018 Ford F250
Old 07-09-2014, 12:58 PM   #8
BamaBob's Avatar
Kaadk,
The thought process here was to switch completely off low pressure city water and use the water in the FWT powered by a higher flow rate water pump to give a more satisfying shower
David is right though - like him, I rarely dry camp and hopefully will not encounter such low water pressure again ) I'd rather spend $80 someplace else than on a water pump that might get used 2 times a year
The accumulator tank for WP noise reduction however sounds interesting.....
Old 07-09-2014, 01:09 PM   #9
Kaadk's Avatar
Originally Posted by HSVBamaBob View Post
Kaadk,
Ah, ok, it wasn't clear that the pressure from your water pump also sucked. The one time I encountered moderate pressure, I just put some in the FW tank and then used the onboard pump to take a shower. Haven't really had any situations where the water pump wasn't as strong as I'm used to seeing in the campgrounds. Then again, I believe the onboard is already a SureFlo. Might make a difference.
Old 07-09-2014, 01:12 PM   #10
Witch Doctor's Avatar
It's my understanding that the pump that they choose to use is the GPM of the # of fixtures it has to supply. An accumulator tank only helps to prolong the cycle that it makes. If you look up sureflo water pumps it will ask the # of fixtures needed then give you a model # to handle that.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
pump, water, water pump
