Old 04-04-2016, 02:15 AM   #1
Sagecoachdriver's Avatar
Water Pump ran continuously ?
Filled FW tank this afternoon, started water pump and turned on 110v water heater switch. We were about to head out on a trip. As I was finishing loading, I heard the water pump running and it wasn't shutting off. I turned on bathroom faucet and normal water came out. It must have been running for 10-15 minutes. I checked everywhere for a leak but found none. We shut off the pump and I opened the low point drain. When empty, I
removed the strainer which had some silicone shaving. Then turned on the pump and it seemed to be working normal again. We are now at a stop for the night and it appears to be OK. I am surprised the pump didn't cause a blow out running that long with no open faucet. Oh, it's a 2016 Forester 2701DS
Any thoughts?
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 10 trips 32 nights
Sagecoachdriver is offline   Reply With Quote
Old 04-04-2016, 02:59 AM   #2
Filling up W/H! Youroo!! Your lucky when you did the "Low point drains" that the Elec element didn't burn out!
youroo is online now   Reply With Quote
Old 04-04-2016, 03:06 AM   #3
Witch Doctor's Avatar
Did it fill your Fresh water tank or was the overflow running over?
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 04-04-2016, 10:10 AM   #4
The water tank didn't overflow, it was full to the top.
The water heater was full from last weeks trip. There was still a third tank of water in the F/W tank and I drained and refilled it prior to turning on the water pump and water heater. Couldn't burn out the electric element as there was always water in it. Draining the low point doesn't drain the water heater, only the lines from it to the faucet and maybe only the cold. My Winnebago Minnie had a hot and cold low point drain, how come only one on the Forester?
Obviously, the pressure cut-off was the issue and I somehow re-set it by removing all pressure. My guess.
Old 04-04-2016, 10:13 AM   #5
Who Dares, Wins
doc73's Avatar
Left mine on over night one time when a piece of sand clogged the pressure switch, that was a year ago, no trouble . After I had done this I read the manual.. I know, crazy right! It said running dry for a long time would not do harm. Mine ran a long time with water in it, just churning.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 04-04-2016, 10:21 AM   #6
Most RV's have a FW tank drain,and a drain for Cold water and a drain for Hot water! Plus a W/H drain plug! Most Rv's WILL drain the W/H from the Hot water Low point drain also,Bringing "White Crud" with it! If you Only have 1 drain it is very rare! Youroo!!
Old 04-04-2016, 10:29 AM   #7
I wonder if I had a science experiment going on in my system leaving the tank sit for 10days and algae clogged the pressure cut-off. There was water pressure when the DW opened the faucet. Anyway, it's working fine now and hopefully for the remainder of our trip. I think draining the line did a re-set.
Old 04-04-2016, 10:47 AM   #8
Sounds like the pressure switch had a hiccup.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 04-04-2016, 11:43 AM   #9
Why only one low point drain, Red with black cap? Blue is FW tank drain.
Old 04-04-2016, 12:40 PM   #10
Well that's good to hear. My water pump has the usual switch on the control panel but there is also one right above the black tank flush hose connection. On our last trip I must have bumped it while doing the tank flush and got home 4 hours later and heard it running. I hope everything is OK. I haven't even put any water in the tank yet as our first few trips have all had city connections.
2016 Rockwood Signature Ultralight 8329SS Platinum
2016 GMC Sierra 2500HD Denali Crew Cab Duramax
TXFolkie is offline   Reply With Quote
pump, water, water pump
