Old 09-12-2016, 01:13 PM   #1
Ann
Water pump replacement
Our Shurflo water pump is leaking and need to get a new one but the old one 2088-422-144 is discontinued so what do we replace it with?
(2004 Forest river-Cardinal travel trailer)
Ann is offline   Reply With Quote
Old 09-12-2016, 01:18 PM   #2
sgtlm17's Avatar
You can go with the shurflo revolution 4008, which seems to be the standard today.
2016 Forester GTS 2801QSF
RVHabit.com
sgtlm17 is offline   Reply With Quote
Old 09-12-2016, 01:19 PM   #3
kenandterry's Avatar
Check the label to see what flow rate you have now. Gallons per minute (GPM)
Then if you're not happy with the performance of the stock unit.....like Tim the Toolman would say....."get one with more power Argh Argh Argh"
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 09-12-2016, 03:30 PM   #4
Ann
it is 2.8 GPM
Old 09-12-2016, 03:55 PM   #5
The 2088-422-144 was the OEM number for the pump. (supplied only to manufacturers)
Aftermarket (available to the public) cross number is 2088-422-444.
It was 12 vdc, 2.8 gpm, 45 psi, 6.5 amp.
There are a few of these available online. (do a Google search)
Even though there are some 2088-422-444 pumps out there, it has been discontinued and the replacement is 4008-101-E65.
It is 12 vdc, 3.0 gpm, 55 psi, 7.5 amp.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 09-12-2016, 05:38 PM   #6
Ann
SHURflo 4008-101-E65 3.0 Revolution Water Pump This what I ORDERED Thanks for the help!!!
pump, replacement, water, water pump
