Old 06-11-2012, 01:22 PM   #11
Dave_Monica's Avatar
Isn't there a check valve before (or after) the pump to prevent the FW tank from filling when on city water? If so, the check valve may be stuck closed not allowing water to be drawn from the tank.
Old 06-11-2012, 01:34 PM   #12
Triathletedave's Avatar
Originally Posted by rracer5 View Post
Does the pump keep running or does it run then stop?
If it keeps running, check to see if you have the suction hose winterizing feature on your water pump, the valve for the suction hose may still be open. AND, the valve between the pump and the FW tank may be closed (as required during winterizing). Check those out and reverse the valves (open FW tank, close suction hose valve).
Let us know.
The winterizing valves all (3) appear to be in the correct position based on the instructions and video. Plus, the winterizing suction hose is removed via a quick-connect at the same point where the fresh water line feeds into the pump (you can only have 1 connected at a time).
I'll check the HW tank tonight to see if it is full or empty. Does that affect fresh water draw if it is empty?
I was thinking of switching the fresh water line back over to the winterizing line, just to see if the pump would draw water from a bucket using the winterizing line. The only thing I can think of is a blockage in the fresh water feed line.
As for the pump, it seems to run constantly when turned on (I.E.: it will not stop due to sufficient pressure buildup). Does that mean that air is getting to the pump somehow?
Dave & Jill
2012 Ford F-150 EcoBoost
2012 Surveyor SV-294
2 kids, one dog (a Golden)
Let's go camping!
Triathletedave is offline   Reply With Quote
Old 06-11-2012, 01:41 PM   #13
MtnGuy's Avatar
Dave, I think why a couple of members here are questioning whether your water heater is full, is that it takes a minute or 2 to fill that. The pump will run during that time without any water coming out of the faucets.
If you ran the pump for 5 minutes without a result, then you can scratch that idea.
Old 06-11-2012, 01:46 PM   #14
Sorry folks, but I'm not near the unit at the moment. I only have occasional access to this forum as well. I'll test all valves and other suggestions tonight. I'd hate to book a service appt for something simple.
In my defense, several other campers took a look at my system, and were equally baffled. Everything looks fine, including the valve positions. The pump hums merrily away, but no water!
Dave & Jill
Let's go camping!
Old 06-12-2012, 09:00 AM   #15
Follow-Up:
Turns out all of the valves were set properly after all. I went around to the HW tank and discovered that it was indeed empty. I opened the pressure relief valve, and immediately felt a blast of air from the tank. After that, I turned the pump on again, and it filled the HW tank first, then I had pressure (actual water) running in the taps!
Could there have been some sort of vapour lock on the HW tank? I was surprised by the blast of air from the valve, which I was not expecting at all.
Regardless, the whole system works now, using either the fresh water tank and the pump, or a city water source alone.
Thanks for the help and suggestions. You've saved me a service appt, which could have taken weeks!
Dave & Jill
Let's go camping!
Old 06-12-2012, 09:04 AM   #16
TURBS's Avatar
Good deal!
My ten gallon hw heater takes 15 minutes to fill.
And will not fill if pressure relief valve isn't open or hw tap is in off position.
That's why I questioned if it was full or not.
Old 06-12-2012, 09:07 AM   #17
[QUOTE=Triathletedave;209232]Follow-Up:
Yes, that is what is called a vapor or air lock - why I always use city water hook up & open the pressure relief valve first thing after the unit has been winterized - seems to do a better job of getting all of the air out of the lines.
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
Emptypockets is offline   Reply With Quote
Old 06-12-2012, 09:42 AM   #18
TURBS's Avatar
X2
Old 06-12-2012, 09:52 AM   #19
Good to know. I'll be adding a new item to my winterizing / de-winterizing checklist!
Dave & Jill
Let's go camping!
Old 06-12-2012, 10:36 AM   #20
TURBS's Avatar
Another thing Dave,
I drain my hw heater after each use as I tend to get a sulfer smell if the water sits in tank for a few weeks.
This may or may not happen to you but just an Fyi.
pressure, water pump
