Old 08-12-2011, 09:46 PM   #1
buzzmonster's Avatar
Water pump runs randomly
Our water pump has been starting by itself with no water being used for a couple of trip now. I have looked for a leak but cannot find one . We do empty the fresh tank so air probably gets introduced could this be the cause ?
Otherwise any tips on where to look for a leak ? If it is a leak it must be really small as I cannot find any water plus the pump only start every 20 mins or so for about 1 second.
Could it be a problem with the pressure switch that starts the pump ?
Thanks in advance
Andy and Jill
buzzmonster is offline   Reply With Quote
Old 08-12-2011, 10:11 PM   #2
JoeR's Avatar
I had a similiar issue and it was a leak. Mine was leaking around the toilet valve and I didn't find it until it ran out where I could see it. Good luck.
JR
JoeR is offline   Reply With Quote
Old 08-12-2011, 11:04 PM   #3
Is there a non return valve in the pump ? Could it be that I am getter a slight leakage from the pump discharge (pressure side) to suction side ?
I will look again for leaks tomorrow but have already been through the camper once and cannot find anything !!
It is a Roo 21rs by the way
Old 08-13-2011, 04:55 AM   #4
DAISY BOYKIN's Avatar
Air leak at the pump---
Check the inlet fittings near the pump for a suction "air" leak, they may appear to be tight because of no water leak. Double check for suction "air" leak. Vibration of the pump running will cause the threaded fittings to become loose.
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 08-13-2011, 06:01 AM   #5
CLASS "A" Senior Member
cfsoistman's Avatar
You could be losing pressure at the check valve at the pump. The seal may not be mating 100% and the pressure only needs to drop enough and the pump will repressurize the line.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 08-13-2011, 06:33 AM   #6
Herk7769's Avatar
If there is no leak on the pressure side; my money is on the check valve too. Depending on your pump, the check valve may or may not be repairable.
RV Water Pumps: Class Series Water Pumps, Extreme Series Water Pumps, General Purpose Pumps – SHURflo RV Products & Solutions
http://www.shurflo.com/files/RV-Prod...2-144_444_.pdf
http://www.shurflo.com/files/RV-Prod...3-143_443_.pdf
HAM CALLSIGN - KC3FFW
Old 04-30-2012, 03:41 PM   #7
trudinator's Avatar
Just saw this thread. So being relatively new to the whole TT scene, your pump shouldn't be running at all when you don't have a faucet or the toilet running? Our pump will randomly turn on throughout the day and night. Even during the middle of the night. DH said it was normal. I would say its not, by reading this thread. Opinions? Solutions, etc.?
2012 Rockwood 8293RKSS
trudinator is offline   Reply With Quote
Old 04-30-2012, 04:02 PM   #8
TURBS's Avatar
My vote is air isn't out of the system yet.
Every year I had this problem the first trip sometimes the second.
After that it was fine rest of the year.
Also if you have one check the strainer bowl by the pump.
I'm sure herk has a pic.
Mine was loose this year causing the pump to run once and awhile.
check low point drain caps to.
Old 04-30-2012, 04:38 PM   #9
A water leak will also cause the pump to cycle, worse the leak, more often. Old trailer, a couple of seconds every couple of hours, new trailer not at all until the valve fell apart for the outside shower. Got it back together best I could, was once an hour or so and got more frequent as time went on. No problems since I replaced the valve. Wayne
wayne anthony is offline   Reply With Quote
Old 04-30-2012, 04:54 PM   #10
Timely I originally posted this thread. Took our pump apart last night, the check valve was passing. It is an integral part of the pump, simple fix took it all apart cleaned the seat on the PTFE disc and then simply put a really small spacer behind the spring to slightly increase the seal pressure when I blow backwards pump no longer passes !!!
Will put it back in the trailer tonight and check it all works.
2011 F150 Ecoboost Screw 4x4 c/w max tow
2010 Roo 21RS
