Old 07-19-2015, 06:41 PM   #1
Water Pump Sometimes Runs when not calling for Water
Hi, everyone. Last week, I was camping with my Rockwood MiniLite 2109S in a state park that had no water hookup. So, I filled my freshwater tank and turned on the water pump. Everything worked fine. However, just occasionally (maybe once or twice a day), I would hear the water pump running even though I wasn't asking for any water. When this happened, it would only run for a second or so and then shut off right away. I checked for dripping faucets, but they were all securely closed. I also checked as best I could for leaks in any water lines, but couldn't find any. Any idea why this happens?
2018 Grand Design Imagine 2600RB
2017 Ford f150 XL Supercab 4x2, 3.5L Ecoboost, Max Tow Package, 3.55 Rear Axle, air bags
Equal-i-zer 1000/10,000# Hitch
Mark Ulmer is offline   Reply With Quote
Old 07-19-2015, 07:49 PM   #2
bikendan's Avatar
Most common cause is a water or air leak somewhere.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 07-19-2015, 08:46 PM   #3
Check valve may be leaking by when the pump is off.
2013 Rockwood Signature UltraLite 8319SS
propbndr is offline   Reply With Quote
Old 07-19-2015, 08:56 PM   #4
GLCM Warrior
Lefty59's Avatar
We've experienced the same thing. I've noticed it seems to normally occur when the temperature changes from nighttime to daytime or the hot afternoon cools into evening. I've just assumed it is a pressure variance in the pex piping caused by the temperature variations. I think it also could be caused by expansion or contraction in the contents of the water heater tank.
Either way, I haven't seen any signs of leakage so I've not been too concerned as it is a fairly infrequent occurrence.
Happy camping!
2014 Wildcat 312QBX
2014 Ford F350 SD 4X4 CC LB 6.7L PSD
Bob & Debbie, USAF Retired
Lefty59 is offline   Reply With Quote
Old 07-19-2015, 09:03 PM   #5
BooBoo23's Avatar
I don't very often need to use the water pump (winterizing is about the only time), but I don't leave it turned on. I turn it on when I have a demand then turn it back off. My system doesn't leak down so I don't have the occasional on/off of the pump. It may be a leaking check valve on the pump since you can't find any drips anywhere.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
BooBoo23 is offline   Reply With Quote
Old 07-20-2015, 12:22 PM   #6
kg4gfv's Avatar
Sounds like check valve to me. Just replaced mine for around $17
2009 Flagstaff Classic Super Lite 831flss
2010 Toyota Tundra CrewCab Max 5.7L
kg4gfv is offline   Reply With Quote
Old 07-20-2015, 12:23 PM   #7
fedexflyer's Avatar
if you have an ice maker in your refrigerator it may just be coming on to make ice a couple times a day. I used to turn my water on when underway only when I need it, but was always short on ice, now I leave it on while I drive and have plenty of ice.
USCG Ret
2011 Sportscoach Pathfinder 405FK
2018 Jeep Wrangler Unlimited Rubicon Recon
fedexflyer is offline   Reply With Quote
Old 07-20-2015, 12:26 PM   #8
Thanks for the replies, everyone. No icemaker, fedexflyer, so that's not it. I'll take a look at the check valve.
Old 07-20-2015, 12:42 PM   #9
KAS
I have noticed the same thing, and also that the pressure INCREASES by itself. Both occurrences seem to be caused by temperature fluctuations in the water that is sitting in the pipes (shade or air conditioned vehicle vs. sun beating down on the RV). As long as there is no visible leak anywhere, this shouldn't be a problem. However I do wonder whether the excessive pressure buildup could cause a leak.
KAS is offline   Reply With Quote
Old 07-21-2015, 01:14 AM   #10
As already stated, it could be a very small leak anywhere in your plumbing. One more place to check is the check valve in your city water port. I've had problems before with that valve re-seating after city water usage.
Try removing the screen/washer inside the city water port and then push the valve in to release some pressure (and water). When you release the valve it will re-seat, hopefully with a better seal. At least in my case it did. If the pump now stays off, then that would be a pretty good indicator that it is time to replace your city water port.
Cathy & Jeff
Midland, Michigan
2013 Sabre 32RCTS / 2012 Ram2500 Hemi
SimchaSabre is offline   Reply With Quote
pump, water, water pump
