Old 06-22-2015, 06:41 AM   #1
muddyrode's Avatar
water pump starts every 2 min
ok went out this weekend to a county park that did not have city water hook up so filled the fresh water tank but when the pump was powered on tabout every 2 min the water pump would burp on to keep pressure i have went thru evry thing and can find on leaks has any one replkaced a water pressure switch on there pump this is on a 2012 wildcat sterling 32RL
2013 3500HD DRW Silverado Duramax
muddyrode is offline   Reply With Quote
Old 06-22-2015, 07:02 AM   #2
Did you check if it was (Leaking) back to Supply tank? Youroo!!
youroo is online now   Reply With Quote
Old 06-22-2015, 07:03 AM   #3
KennyGolub's Avatar
Mine does that, but I have a fairly obvious leak in the water bay.
Waiting for Goshen to get it fixed.
KennyGolub is offline   Reply With Quote
Old 06-22-2015, 07:09 AM   #4
Georgia Frog Rally 2017
aceinspp's Avatar
Maybe a leaky faucet or stool. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2015--46
Days booked for 2016--60
Days camped in 2016 so far 51
aceinspp is online now   Reply With Quote
Old 06-22-2015, 07:53 AM   #5
RSchleder's Avatar
I have replaced the pressure valve/switch in these water pumps. Very easy, refer to the owners manual for the pump, buy or order the correct replacement part (inexpensive) and install per the instructions or Google for video's.
Days camping (2015)----88 days
Days camping (2016) ---110 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi
30 years RV'ing
12 different RV's
RSchleder is online now   Reply With Quote
Old 06-22-2015, 08:33 AM   #6
Islander's Avatar
X2 the pressure valve/switch
If it is the switch ... when you are hooked up to 'city water pressure' you will be slowly filling your water tank as well.
'07 WildCat 30 RLBS ~ West Coast Edition ~
Trail Air - Tri Glide Pin Box
2000 F350 DRW 7.3 Diesel Lariat 89k miles
Edge programmer, 4" SS exhaust turbo/back
Vancouver Island, B.C., Canada
Islander is offline   Reply With Quote
Old 06-22-2015, 08:42 AM   #7
Ret E-9 Anchor-clanker
donanddona's Avatar
Mine would "WEEP" and cause the pump to cycle every 2-3 minuets. This was at the rear toilet. The valve seeped and was hard to see. When on city water I never knew it. I would verify the tank level on city water and that might be easier by a long flush, leaving the drain valve(s) open for an extended period, then closing and rechecking again in a day or two. Good luck....
donanddona is offline   Reply With Quote
Old 06-22-2015, 12:04 PM   #8
Two overlooked areas are always a small drip at the water heater pressure relief valve and the city water hose connection (check valve )
hillsdaletc is offline   Reply With Quote
Old 06-22-2015, 12:10 PM   #9
Water Pump
My 2015 Micro Lite 23FB Does that too.
It was doing about every 15 to 20 minutes.
The last time I pressured up the system I made sure and opened the pressure relief valve on the hot water heater to bleed the air out of the water heater.
The pump still cycles but not as frequently. I am convinced it is either trapped air in the system or a leaky check valve.
pokateps is offline   Reply With Quote
Old 06-22-2015, 03:04 PM   #10
RVPP's Avatar
If you turn the pump off for several days, does it run for a longer period of time when you turn it on? If so I would say you have a leak and it would be worth your while to find it and fix it before to damages something, like the floor.
Good luck.
RVPP is offline   Reply With Quote
pump, water, water pump
