Old 06-21-2016, 09:18 PM   #11
Left Coast
Have an enclosed underbelly?...
Retired....but work part time as a pain in the north end of a south bound donkey.......2010 Rockwood 8280 5er....99 Dodge 2500 turbo Cummins
bob caldwell is online now   Reply With Quote
Old 06-22-2016, 05:51 AM   #12
northstar1960's Avatar
to be honest if you have to ask you should hire someone to do it
northstar1960 is online now   Reply With Quote
Old 06-26-2016, 07:23 AM   #13
I had a similar problem yesterday after sanitizing and flushing my fw system. I couldnt build any pressure and my pump wouldnt turn off. After some troubleshooting, I removed the strainer located on the pump. It was completely blocked with all kinds of gunk. Cleaned it and put it back together. Works great now. Might be worth looking at?
Mustng78 is offline   Reply With Quote
Old 07-06-2016, 11:19 AM   #14
I just tried partially filling freshwater tank and using the water pump. I get a solid 10 seconds of water before it trickles to nothing. I have cleaned the screen and problem still exists. The pump builds pressure and shuts off. I'm tempted to purchase a replacement as warranty work has taken forever. Any other suggestions?
I tried to check the tank hook up and peeled some of the spray foam to try to get to connection with no luck. All other connections are tight.
This is a 2016 unit so it shouldn't really be a pump issue
'16 Cherokee 274DBH
'16 F150 XLT Crew 3.5eco
Mike
2016 Cherokee Limited 274DBH
2009 Ford F-150
Michael4017 is offline   Reply With Quote
Old 07-13-2016, 02:52 PM   #15
Summer2Go
Summer2Go's Avatar
Don't you have to hit the flow valve on the pump?
Summer2Go is offline   Reply With Quote
Old 07-13-2016, 03:09 PM   #16
What's that?
'16 Cherokee 274DBH
Mike
2009 Ford F-150
Old 07-13-2016, 06:31 PM   #17
Summer2Go
Summer2Go's Avatar
To use the fresh water tank do you have to turn the switch on the water pump, or is that only winterization? I have a anti- freeze inlet. I am actually trying to use water from my fresh water tank right now, and the water sounds in the hot water tank have been "filling" for a couple of hours. Something is wrong, so I am trying to figure it out. Do you just go from city water to fresh water tank by simply turning on the pump?
Old 07-13-2016, 06:32 PM   #18
Left Coast
Yes
Sent from my XT1585 using Tapatalk
Old 07-13-2016, 06:33 PM   #19
Left Coast
If fresh water tank has water
Old 07-13-2016, 06:42 PM   #20
Left Coast
And, make sure winterizing valves turned correctly
pump, water, water pump
