Old 05-06-2014, 07:55 PM   #1
Steeljag's Avatar
Water pump use
Good evening, I just read some posts on water pump usage and want to say I have never used ours.......ever......zippo.....lol.
We have so far always stayed at State parks with hookups.
Anyway, without me walking outside and over to the TT garage to grab manual, I would like to ask how the system works? Once I add fresh water to the tank and turn on pump is anything else required? Valves need to turned from standard hose hookup?
Will the battery power the water pump? Need shore power?
1930 lbs CCC
2014 Jeep Rubicon JK
Steeljag is offline   Reply With Quote
Old 05-06-2014, 08:00 PM   #2
TURBS's Avatar
All you have to do is fill fw tank and turn on the pump.
Yes the pump runsvon battery power.
You don't "need" shore power but shore power is what is used to charge the battery.
TURBS
Sabre owners united!
Old 05-06-2014, 08:10 PM   #3
Also remember before leaving to drain tank with drain valve so you're not carrying extra weight. Unless you want some water for traveling.
2012 F350 Lariat CC SRW 6.7L Powerstroke
pwrstroke2012 is offline   Reply With Quote
Old 05-06-2014, 08:12 PM   #4
mark0224's Avatar
most state parks here don't have water hook up so you have to use the pump. Usually tur it on when we need water and turn it off when done.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 05-06-2014, 09:19 PM   #5
Steeljag's Avatar
Thanks folks, I do plan to experienment with it soon.
1930 lbs CCC
Old 05-06-2014, 10:51 PM   #6
Ret E-9 Anchor-clanker
donanddona's Avatar
Leave a little in the FW tank for the wife's side of the road rest stops. Sometimes it's nice to carry the potty room with you.
donanddona is offline   Reply With Quote
pump, water, water pump
