Old 04-14-2013, 07:22 PM   #1
water pump vibrates
I have a 1999 rv with a shur flo diaphragm pump which is probably the original one. it recently started to vibrate all the plumbing hoses when using water.
should I replace or is there anything else I can do
allphase is offline   Reply With Quote
Old 04-15-2013, 06:16 AM   #2
Herk7769's Avatar
Shurflo makes a silencer kit.
Isolating the pump from the hard PEX tubing with soft flexible hose will help.
Mounting the pump with a thick mouse pad or soft rubber pad will also help.
SHURflo Pump Silencer Kit - Hypro-shurflo Llc 94-591-01 - Fresh Water Pumps - Camping World
Name:	Pump Storage Diagram.JPG
HAM CALLSIGN - KC3FFW
Old 04-15-2013, 07:00 AM   #3
That silencer kit is worth the $$.... but if you don't want to spend all the $$ - we added the accumulator first (before they offered a kit) and that help eliminate 90% of the banging.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 04-15-2013, 07:16 AM   #4
Mount the pump on a board with vibration isolation dampers in the board like these. You have to isolate the pump from the floor. Isolate It!: Sorbothane Vibration Isolation Bushing 50 Duro (.25" ID - 1" OD - .6" Deep) - 12 Pack - Amazon.com
Old 04-15-2013, 07:40 AM   #5
Fulltime family RVer
My question would be what caused it to start vibrating? Was it quite before and now makes noise?
ependydad is online now   Reply With Quote
Old 04-15-2013, 09:59 AM   #6
it was quiet before
