Old 10-31-2013, 01:43 AM   #1
Water Pump Winterize
2014 24 ft Grey Wolfe
I ran 4 gallons thru the cold side lines, pink antifreeze flowing. No antifreeze came thru the hot side, Dumped plenty in to the p-traps. Where is the water heater/pump by-pass valve? And where is the darn thin located? I found the water tank with lots of valves to the right of the bathroom sink behind the very thin panel with 2 screws in it. Lots of valves with lots of confusion. You help is appreciated. Any you-tube sites or others showing this would be helpful. Called Forest River & got the run around. Thanks. Phil.
Phil Casey is offline   Reply With Quote
Old 10-31-2013, 06:55 AM   #2
Dave_Monica's Avatar
You'll need to access the backside of the water heater and set the valves as shown in the photo.
Dave
pump, water, water pump, winter, winterize
